How to display different column values on reference fields on a form?
Sai_Dilip
So, I have 3 fields on a catalog referenced to "cmn_location" as follows:
1. City
2. State
3. Country
Currently the "Name" field on the "cmn_location" table has the Display Value set as "True", but I need to show City, State & Country on the respective fields. Any possible method for this?
Ankur Bawiskar
@Sai_Dilip
you will require 3 different lookup select box variable referring to "cmn_location" table
In each of those have Lookup label as City, State, Country respectively
mayankkumar
Hi @Sai_Dilip,
Go with the LookUp select box approach as @Anand__99 , @Ankur Bawiskar suggested
Please mark my response helpful and accept as solution
Thanks & Regards
Mayank
