how to get related incidents for a problem record
rudra8
hi everyone,
 i have a doubt. how to get all related incidents which are attached to a problem record  . for example if 3 incidents are attached to a problem i want to display those incident number in a field ( let us say  for ex: description field).
i written the code using business rules:
var string=[];
var obj={};
var gr=new GlideRecord("incident");
gr.addQuery("problem_id","=",current.sys_id);
while(gr.next())
//current.work_notes=gr.getDisplayValue('number');
string.push(gr.getDisplayValue('number'));
for (var i=0;i<string.length;i++)
current.description=string[i].number;
any help is appreciated.. thank you
Can you try below :
var string=[];
gr.addQuery("problem_id",current.sys_id);
while(gr.next())
string.push(gr.number.toString());
current.description=string.join(',');
current.update();
hvrdhn88
Giga Patron
if you are using business rule then you should not use current.update().
on which table are you running this business rule? problem or incident?  if you are running on problem table then
gr.addQuery('problem_id',current.sys_id);
if on incident table
gr.addQuery('problem_id',current.problem_id);
i assume you are running on problem table .just try.
var check=[];
while(gr.next())
check.push(gr.number);
current.description=check;
