How to get system properties client side?
peterraeves
Mega Guru
What's the client side equivalent of 'gs.getProperty'?
Chuck Tomasi
I prefer to use a Display Business Rule and put the property in to a g_scratchpad variable. You can then use it in an onLoad script.
BR:
g_scratchpad.my_property = gs.getProperty('my.property');
CS:
var myProperty = g_scratchpad.my_property
I believe we covered this in episode 5 of TechNow.
TechNow Episode List
14 REPLIES 14
Hi Chuck,
We have got a similar requirement to retrieve a sys_property is UI page client script but the asynchronous GlideAjax returns the value after the page is being rendered which is not expected.Tried calling g_scratchpad but haven't had any luck though.
Any suggestions are truly appreciated.
Zabeeulla.
For standard form behaviors, this, or setting a session variable is how I'd normally accomplish it.  However, if I want to use this behavior in the catalog for a specific catalog item, how would I do this?
-Stephen
Thanks Chuck, I was in need of creating a system property to be available client side and this solution worked perfectly!
Happy to help. Good to know my old posts are still working. 🙂
What if my clint script isa Catalog Client Script? I think I can not use Business rules for that.
P.D. I'm a big fan of your work and the best practices that you show us
