How to Hide related links and related lists using client script or UI policy on portal for standard changes
SumanthMora
Mega Guru
How to Hide related links and related lists using client script or UI policy on portal for standard changes (without updating the condition on the respective UI actions)
Here you go:
https://community.servicenow.com/community?id=community_question&sys_id=fe344e92dbbc5b404fc2f4621f96...
Please mark my response as correct and helpful if it helped solved your question.
-Thanks
9 REPLIES 9
Thank you. Is there a way to hide related links?
Those related links are UI Actions. To hide them from anyone who is not an admin, you would right click on the link, choose Edit UI Action and add something like gs.hasRole('admin') to the condition field.
If i was able to solve your query, please mark my answer correct and helpful.
Thanks & regards
Prasant kumar sahu
Prateek kumar
Check this out:
https://community.servicenow.com/community?id=community_question&sys_id=fcfcf77edb435f082be0a851ca96...
-Thanks
Thank you. But how to hide Related Links?
Here you go:
-Thanks
