01-23-2025 08:33 PM
I am trying to map the choice field of a snow user profile through flow designer. we get user data through an integration and value should be mapped to field in snow user profile dynamically based on the input we receive as we have different choice values in snow end. trying with below script but it is returning empty value:
01-23-2025 08:50 PM
Hi @klavan32
Please check the following points:
1. Remove if (get(empType)) from your script.
2. What is the value being returned by employee_type variable. For that, please check the flow execution context and see the value. Compare the value being returned with your if-else logic.
3. If the empType variable is being set properly, check for the choice field values. As per your script, your choice field has values like full_time_employee etc. Please cross-verify the same.
Thanks and Regards
Amit Verma
01-23-2025 08:57 PM
**Access Flow/Action data using the fd_data object. Script must return a value.
var empType = fd_data._1__get_employee_data__snaplogic.employee_type;
var fte = 'full_time_employee';
var con = 'contractor';
var ctg = 'contingent';
if (empType) { // Check if empType is defined and not null
if (empType === "Employee") {
return fte;
} else if (empType === "Contractor") {
return con;
} else if (empType === "Contingent") {
return ctg;
return ''; // Return empty if no match found
return ''; // Return empty if empType is undefined or null
01-23-2025 08:57 PM
01-23-2025 09:09 PM
This indicates that you have not defined the output variable employee_type in
action or if you have defined the output variable, check the variable name. Use dot-walking to get the variable value while scripting.
Can you please share your action configurtion?
01-23-2025 09:18 PM
it means you are not taking the value correctly
Please share complete flow steps along with screenshot
Is that flow on catalog and that is a variable?
If yes then you should use Get Catalog Variable action and then dot walk and get that variable value
01-26-2025 10:27 PM
Hi @Ankur Bawiskar here is the action details that we have configured.
script step :
outputs:
As per the error, it is mentioned that employee_type in output is not defined
when we tested the action , we got employee_type details in output message[string] as below:
We wanted to add this update to already exisiting configuration and mapped as same as per existing.
