how to print array output in flow designer > action
skumar_srbh
I have created an Action, where I am trying to fetch the Incident's assignment group members email ID,
incident number is the input and in script section i am fetching the value from sys_user_grmember table. in the end of script part, I have added a log to print- "output.user_emailID", and can see email ID values are populating. however when i see the execution of Action, its shows blank.
My question is, in the above screenshot, are all email IDs from group should show in front of User Ids field ?? as Further I am using this action into a for each loop in a flow, it's not working.
Thanks in advance for help,
Kumar
Try this
looks like i had some variable issue, now it worked
Sandeep Rajput
@skumar_srbh Did you map the output of your script in the Action to the output of the action? If no then the output variable would appear as empty.
