03-23-2020 10:38 PM
I want to set a person who belongs to the same department as the applicant's department.
But it returns an error..
What's wrong?
Script Include:
var getMyDepartments = Class.create();
getMyDepartments.prototype = {
initialize: function() {},
getDepartmentUsers: function() {
var usersList = "sys_idIN";
var grUser = new GlideRecord('sys_user');
grUser.addQuery('company', gs.getUser().getCompanyID());
grUser.addQuery('department', gs.getUser().getDepartmentID());
grUser.query();
while (grUser.next()) {
usersList = usersList + ',' + grUser.sys_id;
type: 'getMyDepartments'
variable Reference qualitifier:
System log:
Script Debugger
Scripting and Coding
03-24-2020 12:27 AM
you can create new one with some other name and keep accessible from as All application scope
var getMyDepartments2 = Class.create();
getMyDepartments2.prototype = {
var userRec = new GlideRecord('sys_user');
userRec.get(gs.getUserID());
var department = userRec.getValue('department');
var usersList = [];
grUser.addQuery('department', department);
grUser.query();
while(grUser.next()) {
usersList.push(grUser.getUniqueValue());
return 'sys_idIN' + usersList;
type: 'getMyDepartments2'
call it like this from ref qualifier:
javascript: new x_223778_upload_li.getMyDepartments2().getDepartmentUsers();
03-23-2020 11:45 PM
as you are using this in scoped app this won't work
so update code as below; query logged in user record and get the department value
Also the field from where you are calling is it in your 200 Upload Limit scope; I could see the script include is in that scope and accessible only from same scope;
If that user field is in global scope then it won't be able to call this script include as it is accessible only in same scope
var getMyDepartments1 = Class.create();
getMyDepartments1.prototype = {
var usersList = [];
grUser.query();
type: 'getMyDepartments1'
03-23-2020 11:58 PM
Thank you politely.
Do I need to create this script include in Global?
03-24-2020 12:27 AM
var usersList = [];
grUser.query();
03-24-2020 02:26 AM
I worked it!
Thank you so much.
01-01-2023 03:33 AM
