HR Metric Help
Danielle10
Good day!
New metric for when an HR Case is opened until the HR Case hits the awaiting acceptance state?
Thank you for your help!
Robbie
Hi @Danielle10,
Please find the below screenshot and script that will help achieve this for you (Tried and tested on the HR table on my PDI - Personal Dev Instance).
Please note @Danielle10 - This Metric will only be created when the HR Case is saved in the state of 'Awaiting Acceptance'. (And not before)
To help others (or for me to help you more directly), please mark this response correct by clicking on Accept as Solution and/or Helpful.
Thanks, Robbie
Screenshot (A new 'Metric Definition')
Script:
// variables available
// current: GlideRecord -  target incident
// definition: GlideRecord -  (this row)
var s = current.state;
if (s == 20)
  createMetric();
function createMetric() {
  var mi = new MetricInstance(definition, current);
  if (mi.metricExists())
  var hrCaseAwaitAcc = mi.getNewRecord();
  hrCaseAwaitAcc.start = current.sys_created_on;
  hrCaseAwaitAcc.end = current.sys_updated_on;
  hrCaseAwaitAcc.duration = gs.dateDiff(hrCaseAwaitAcc.start.getDisplayValue(), hrCaseAwaitAcc.end.getDisplayValue());
  hrCaseAwaitAcc.calculation_complete = true;
  hrCaseAwaitAcc.insert();
13 REPLIES 13
Hi @Danielle10
No need to add start / end time. once you save this metric and update the HR case then it capture automatically.
This will require scripting to appropriately capture the start and end points. Any idea on how to formulate this script?
NO scripting at all, system will do all calculation for you.
Danielle10
Thank you.
put HR table instead of Incident table .
