Interceptor: passing dynamic values using Interceptor’s Target URL or Script field
rhiannone1
I have the following set up, from a Problem you are able to raise a related Change request using a UI Action form link. The Problem needs to be assigned to the raised Change request. I am using an Interceptor so the resolver has a choice in the type of Change request raised, e.g. emergency, standard etc.
Currently, I am unable to pass the sys_id of the Problem to the Change request. How can the sys_id of the Problem be passed using the interceptor form, either in the Target URL field (using a script include for example) or via the Script field?
Rhiannone
Hi Hardik,
Did you get solution for it? Passing dynamic value in interceptor's url.
Thanks!
BR,
Manisha
Hii Manisha,
Since it was a long time ago, I don't exactly remember what was my ask.
Can you please explain what is your requirement here?
