Is it possible to get data of reference fields without using Script include?
_raj_esh
Hello Guys,
I am trying to understand the process to get the data of reference fields.
Example:
A REQ000111 has Opened_by reference filed and is referred to User table. And on the user table, another reference field is called Location.
The Location has different variables. Example City, Country, etc.
How can we get the value of City or State without using Script Include?
Help on this is much appreciated.
Raj
--Raj | ServiceNow Certified Technical Architect
_raj_esh
Thank you @Paul Morris and @sudeepptr
Looks like have to use script include, without which the values are not retrieved.
Code for reference:
Script Include:
getlocation: function() {
var sys = this.getParameter('location_id');
var cm_loc = new GlideRecord('cmn_location');
if (cm_loc.get(sys)) {
gs.log('location ' + cm_loc.country);
answer = cm_loc.country;
gs.log('answer' + answer);
return answer;
Client Script:
var l = g_form.getReference('opened_by');
var ll = l.location;
ga.addParam("sysparm_name", "getlocation");
ga.addParam("location_id", ll);
ga.getXMLWait();
// alert(ga.getAnswer());
var loc = ga.getAnswer();
alert(loc);
If you want to access that directly in the business rule you can just dot walk that. https://docs.servicenow.com/bundle/rome-platform-user-interface/page/use/navigation/reference/dot-walking-examples.html
Hi Sudeep,
Thank you, but I am looking more on the jelly or the client scripts to get the values.
Raj
_raj_esh
Code for reference:
Script Include:
return answer;
Client Script:
ga.getXMLWait();
alert(loc);
