Is there is a OOB solution for running powershell scripting to update sql database via flow
12-21-2023 11:41 AM
We are trying to update SQL database via PowerShell , Do we have any OOB solution for that ?
12-26-2023 09:31 AM
Sure.
12-26-2023 09:48 AM
Hi @RudhraKAM
PFA the update set.
You need to configure the credential for the connection alias that I have created as part of this update set.
| C |
If the provided solution meets your needs, kindly consider marking it as helpful and accepting it as the solution. This helps others who may have similar questions. |
12-28-2023 12:39 AM
Hi @RudhraKAM
| C |
