ISSUE : Get List Collector Value in Flow and use value in FOR EACH loop
Sohail Khilji
Dear Community !
I have an issue with a list collector field value in flow desinger.
Objective :
I want to collect the list of CIs in a list collector and use in flow designer to set them as Non-Operational. I tried to create a custom Action and use in flow to parse with split(','). But had no luck. Seems like the issues is with input and output value types such as array.object or array.string.
i Tried both but no luck, in flow log i get return value as [Object Glide Record].
Error Log:
INPUT:
SCRIPT :
OUTPUT:
@Ankur Bawiskar , I refered to your article too... can you help in this case?
@Community Alums , @Sagar Pagar.
Josh Pirozzi
Hey @Sohail Khilji,
Thanks for your details here! We've been trying to work on a similar dev effort and the Custom Action isn't working for us either.
I'm not sure if you're still experiencing this issue/situation, but I was able to come up with a potential solution without using the Custom Action. See my comment on: https://www.servicenow.com/community/developer-blog/using-list-collector-in-flow-designer-for-each-l...
Josh Pirozzi
Hi @Sohail Khilji,
I just wrote up a post for it where I included a step-by-step along with screenshots.
Hope it helps!
- Josh Pirozzi
https://www.servicenow.com/community/developer-forum/flow-designer-amp-list-collector-quot-for-each-...
