Issue with Client Script Not Working After Moving from Dev to Test Instance
sunilsargam
Hey folks, I’m facing a weird issue and hoping someone here can help me figure it out.
I’ve written a client script that shows/hides form sections based on the ticket type. In my Dev instance, it works great—no issues at all.
But when I migrate that same script to my Test instance, it doesn’t work. I've tried everything: re-importing via update set, validating the script, even checking for possible conflicts. Nothing seems to fix it.
Here’s the kicker: if I manually recreate the same script directly in Test, it works perfectly. Same code, same settings—just created fresh.
So now I’m wondering:
  • Is it something to do with update sets not transferring something essential?
  • Could there be caching issues that prevent the moved script from triggering?
  • Am I missing a setting that doesn’t copy over?
Would love to hear if anyone has run into this kind of problem and what you did to fix it. Thanks in advance!
Pranesh072
Can you share the client script you imported from dev and one you directly created on test.
Ruchi Kumari1
were you able to fix this ? I am facing exact same issue.
