JDBC connection for Snowflake using Key Pair Authentication
‎06-06-2022 07:19 PM
Hi all,
We are trying to establish JDBC connection to Snowflake using Key Pair Authentication. I have uploaded the Snowflake drivers JAR to Mid Server and configured a data source to build connection string to pass private key and password as per https://docs.snowflake.com/en/user-guide/jdbc-configure.html#using-key-pair-authentication.
However, I am getting following error while loading data into ServiceNow
MID Server reported error: java.sql.SQLException: net.snowflake.client.jdbc.SnowflakeSQLException: Private key provided is invalid or not supported: D:/snowflake/privatekey/rsa_keyP.p8: Cannot retrieve the PKCS8EncodedKeySpec
How can this issue be resolved as our internal security policies to connect Snowflake allow to use only via private that is encrypted?
Thanks!
Integrations
‎07-29-2025 10:03 PM
Hello @Sanjay Sharma ,
Hope you're doing well!!!
We have a requirement to establish a JDBC connection to Snowflake using Key Pair Authentication. If you’ve successfully set this up on your end, could you please share the steps you followed?
Thank you in advance!
‎07-29-2025 11:29 PM
I am also looking for connection URL with private key
‎10-28-2025 11:19 AM
Hi @Sanjay Sharma ,
We also have a similar requirement. Could you please guide on the steps or documents to set this up.
Thanks & Best Regards,
Shalini Jain
‎01-06-2026 08:57 AM
Anyone has implemented snowflake key pair authentication from ServiceNow. What should be the connection url to be updated in BR if we are using key pair authentication and also to which location should the files be uploaded?
‎10-06-2026 01:42 AM
Has anyone been able to setup connection using private key ?
