List Collector Ignores Reference Qualifier – Script Include Not Working?
Erica2
Hellow,
I'm currently trying to learn how to properly call a Script Include from a List Collector variable's Reference Qualifier.
However, it seems that the list still returns data regardless of whether the Reference Qualifier is calling the Script Include or not.
Could someone please review my code and let me know where I might have gone wrong? Thank you!
List Collector Variable:
Script Include: - It should only return a few inactive records if it is working correctly.
var SoftwareName = Class.create();
SoftwareName.prototype = Object.extendsObject(AbstractAjaxProcessor, {
    getSoftwareNameRefQual: function() {
        var gr = new GlideRecord('u_software_inventory');
        gr.addQuery('active', false);  // Only inactive records
        var softwareNames = [];
        while (gr.next()) {
            var name = gr.getValue('u_software_name');
            if (name)
                softwareNames.push(name);
        return softwareNames.join(',');
    type: 'SoftwareName'
2 ACCEPTED SOLUTIONS
Ankur Bawiskar
@Erica2
why you require script include?
what do you mean by few records? how many 5 or 10 or 100?
you can directly form the encoded query and copy paste there
javascript: 'u_active=false';
Anand__99
Hi @Erica2 ,
Based on your requirement you don't need a script include for this unless you want to validate something or fetching records from another table than glide list table.
Just add the condition to the reference qualifier field:
javascript:'active=false'; // OR just active=false
Anand
14 REPLIES 14
Nishant8
Tera Sage
Hello @Erica2, you seem to have couple of problems in your code, could you plz try as below:
- change your ReferenceQualifier as below
javascript: new global.softwareName().getSoftwareNameRefQual();
- change your return statement as
return "nameIN" + softwareNames.join(',');
P.S: Since you are looking up by name, and there may be more than one entry with the same name, you might find duplicates in your list. It's better to return the sys_id to be on the safer side.
Nishant
adding the screenshot of reference qualifier
Anand__99
Hi @Erica2 ,
Anand
Erica2
Thank you, @Anand__99
It works by using:
YaswanthKurre
Hi @Erica2 ,
List collector accepts sys_id's as return value not the names, so change the script as mentioned below:
        while (gr.next()) {
            if (name)
                softwareNames.push(gr.getUniqueValue());
Mark this as helpful and correct if this solves your question.
Yaswanth.
