need help in business rule
2022_ServiceNow
Hi, I have a business rule which runs on the task table when the particular task state based on the item is changed to closed complete. There is a field in that task 'current.request_item.configuration_item' which is referenced to computer system table. So when task is closed, need to update the field in that record. This is not getting updated.
    var comp= current.request_item.configuration_item;
    var cs= new GlideRecord('u_cmdb_ci_computersystem');
    cs.addQuery('name', comp);
    cs.query();
    while (cs.next()) {
        cs.setValue('install_status', 'Return');
        cs.update();
})(current, previous);
  @Ankur Bawiskar @Amit Gujarathi
2 ACCEPTED SOLUTIONS
What's output of comp in the log, if its reference column then it must be sys_id of record from table [ [u_cmdb_ci_computersystem]
replaced the cs.addQuery('sys_id', comp);
    cs.addQuery('sys_id', comp);  // if comp value is sys_id then apply the query on column sys_id instead of name
    cs.query();
    while (cs.next()) {
        cs.update();
So its returning sys_id , perfect ..also going inside the while loop ( as TEST1 printed in log ).
are you sure that , install_status which is Integer type select box with choice values, I checked the sys_choice table for this install_status,  all values are numeric. Check the same and use the numeric value instead of 'Return'.
13 REPLIES 13
@AshishKM
Script:
Condition:
Logs:
@AshishKM Thank you so much Sir! It's working!
Finally, it's working for you. happy to help. ðŸ˜Š
