Need help in scripting
jayaprakash1998
Requirement:
1. Create a checkbox 'primary support' in group table.
2. In Incident form if assignment group is selected in incident form and if that assignment group check box primary support is true then show an alert message.
I have created the checkbox and writtern script to find the name of the assignment group from incident
I have no idea how to find that assignment group checkbox value from incident form script.
Can anyone help please ?
My script
    var group = g_form.getDisplayBox('assignment_group').value;
    alert(group);
4 ACCEPTED SOLUTIONS
Clara Lemos
Hi @jayaprakash1998 ,
You can try the following for you script :
   var primarySupport = g_form.getReference('assignment_group').u_primary_support; // gets the value of the primary support checkbox ( true or false)
   if(primarySupport=='true'){ // if primary Support is true show alert
	alert(g_form.getReference('assignment_group').name); // alert with the name of the assingment group
If that helps please mark my answer as correct / helpful!
And if further help is needed please let me know
Cheers
Danish Bhairag2
Tera Sage
You can achieve this by creating an onChange client script & a script include please copy the below code
Client Script:
    // Use GlideAjax to check if the primary support checkbox is true for the selected Assignment Group
    var ga = new GlideAjax('CheckPrimarySupport');
    ga.addParam('sysparm_name', 'checkPrimarySupport');
    ga.addParam('sysparm_assignment_group', newValue);
    ga.getXMLAnswer(function(response) {
        if (response == 'true') {
            alert('This Assignment Group is marked as Primary Support.');
Script Include:
Client callable : true
var CheckPrimarySupport = Class.create();
CheckPrimarySupport.prototype = Object.extendsObject(AbstractAjaxProcessor, {
    checkPrimarySupport: function() {
        var assignmentGroup = this.getParameter('sysparm_assignment_group');
        var groupGR = new GlideRecord('sys_user_group');
        if (groupGR.get('sys_id', assignmentGroup) && groupGR.primary_support) {
            return 'true';
            return 'false';
    type: 'CheckPrima
rySupport'
Danish
Prince Arora
Tera Sage
@jayaprakash1998
Can you try this:
   var result = g_form.getReference('assignment_group', myData);
   function myData(result){
      if(result.u_primary_support+"" == "true"){
                alert(result.name);
If my answer solved your issue, please mark my answer as  Correct & 👍Helpful based on the Impact.
Shivam Techlene
Hello @jayaprakash1998,
You can achieve this functionality using multiple ways.
1. Using getReference() inside an OnChange client script. which is also suggested by @Clara Lemos@Prince Arora.
2. Using Onchange client script and a script include combined. The scripts are given below.
Client Script:
Table: Incident
Type: OnChange
Field Name: Assignment Group
    var ga = new GlideAjax('AssignmentCheckbox'); //Script Include Name
    ga.addParam('sysparm_name', 'checkAssignmentCheckbox'); //Script Include function name
    ga.addParam('group', newValue);
	ga.getXMLAnswer(GetResponse);
    function GetResponse(response) {
            alert('Group is primary group');
Script Include:
Client Callable: true
var AssignmentCheckbox = Class.create();
AssignmentCheckbox.prototype = Object.extendsObject(AbstractAjaxProcessor, {
    checkAssignmentCheckbox: function() {
        var group = this.getParameter('group');
        var gr = new GlideRecord('sys_user_group');
        gr.addQuery('sys_id', group);
        if (gr.next()) {
            if (gr.getValue('u_primary_support') == true)
                return 'true';
            else
                return 'false';
    type: 'AssignmentCheckbox'
Please Mark my answer helpful and correct if it helps to achieve your requirement.
Thanks & Regards,
Shivam Jaiswal
Hello @jayaprakash1998 ,
Any updates on this one?
Please mark it helpful & correct if it helps you achieve the solution.
Thanks & Regards,
Shivam Jaiswal
Hello @jayaprakash1998 .
Did you get a chance to try this one?
Kindly mark my answer helpful and correct if it helps to resolves the issue.
Thanks & Regards,
Shivam Jaiswal
jayaprakash1998
