‎09-12-2022 12:46 PM
I have a requirement to create a UI Action that updates multiple release forms based on entries on a UI page. For some reason, my processing script is not working and the fields do not map. What should happen is that: 1. multiple records are selected in the My Groups Work list view, and then 2. the UI action "Validation Sign-Off" is engaged and the mandatory fields are populated and when the "Complete Sign-Off" button is clicked, the selected records are populated, the UI page closes and you are returned to the list view.
What is happening is the UI page is populated and when I click "Complete Sign-Off" it blanks out the fields and goes to a screen that only shows the UI page without updating any records selected. Can someone PLEASE tell me what I'm doing wrong?
The fields that need to be updated are: Validation Complete (validation_complete) and Work Notes (work_notes)
My code is below:
HTML Script:
<g:ui_form>
<g:evaluate>
var currentTable = RP.getWindowProperties().get('current_table') || '';
var sysIDList = RP.getWindowProperties().get('sys_id_list') || '';
</g:evaluate>
<input type="hidden" name="current_table" value="$[currentTable]" />
<input type="hidden" name="current_table" value="$[sysIdList]" />
<table width="400">
<tr>
<td nowrap="true" valign="top" width="600%" height="100%">
<div class="col-md-8">
<span><b><font style="background-color:lightblue">${gs.getMessage('I confirm the application core functionality has been validated and deemed acceptable for use following this release. By checking this box I am signing off on validation.')}</font></b></span>
</div>
<tr>
<td>
<div class="mt-10" style="padding-left:15px;">
<label class="checkbox-label">
<label><b>${gs.getMessage('Validation Complete')}:</b></label>
<g2:ui_checkbox id="validation_complete" name="validation_complete" value="false" />
</label>
</div>
</td>
</tr>
</td>
</tr>
<tr>
<td>
<div class="col-md-8" style="padding-left:15px;">
<label><b>${gs.getMessage("Work Notes")}</b></label>
<textarea wrap="soft" autocomplete="off" rows="5" id="work_notes_update" data-length="4000" style="; width:150%; overflow:auto; background-color:LightGoldenRodYellow;" name="work_notes_update">${jvar_work_notes}</textarea>
</div>
</td>
</tr>
<tr>
<td colspan="2" style="text-align:right; padding-top:10px;">
<button class="btn btn-default" onclick="closeWindow()" style="margin-right:10px;">Cancel</button>
<button class="btn btn-primary" onclick="mass_updates()">Complete Sign Off</button>
</td>
</tr>
</table>
</g:ui_form>
</j:jelly>
Client Script:
function mass_updates(){
g_form.save();
GlideDialogWindow.get().destroy();
function closeWindow() {
Processing Script:
updateMutlipleRecords();
function updateMutlipleRecords() {
var choice = new GlideRecord(current_table);
if (sys_id_list){
var selectedRecords = sys_id_list.split(',');
choice.addQuery('sys_id', selectedRecords);
choice.query();
while (choice.next()){
choice.validation_complete = validation_complete;
choice.work_notes_update = work_notes;
choice.update();
function assign(){
var urlOnStack = GlideSession.get().getStack().bottom();
response.sendRedirect(urlOnStack);
Scripting and Coding
‎09-14-2022 11:09 AM
Hmm... I guess the worknotes field is wrong...
Replace
choice.work_notes_update = work_note_update;
with
choice.work_notes = work_note_update;
As for the redirection, you could simply hardcode the URL:
response.sendRedirect('/incident_list.do');
I think it should work, but I haven't tested it as my PDI has gone offline suddenly!
‎09-13-2022 10:43 AM
Thank you so much!!!
‎09-13-2022 11:47 AM
Replace:
with:
<input type="hidden" name="sys_id_list" value="$[sysIDList]" />
And change your Processing script to:
gs.addInfoMessage('current_table - ' + current_table);
gs.addInfoMessage('sys_id_list - ' + sys_id_list);
gs.addInfoMessage('validation_complete - ' + validation_complete);
gs.addInfoMessage('work_notes - ' + work_notes_update);
if (sys_id_list) {
choice.query();
while (choice.next()) {
choice.work_notes_update = work_notes_update;
choice.update();
(I've added 2 log messages, please verify if the table name and the sysids show up at the top of the screen when the button is clicked)
Edit : Updated Processing script
‎09-13-2022 12:16 PM
Hello
Thank you so much for your help and patience with this issue.
I do see the information messages at the top with the correct sys_ids of the records I am attempting to update but the current table is not the table I want to update and I believe this is why the records are not updating. It is showing me the current table as the rm_task table but the table that needs to be updated is a custom table where the records are actually located: x_namim_edrm_nos_patch_schedule_task
Since my UI Action is on the list view of the rm_task table, it seems I need to call out the actual table I need to have updated - which would be a change to these lines in my HTML script:
change to:
var currentTable = new GlideRecord('x_namim_edrm_nos_patch_schedule_task') || '';
change to:
<input type="hidden" name="current_table" value="$[x_namim_edrm_nos_patch_schedule_task]" />
And change this line in my Processing Script:
Is that correct?
‎09-13-2022 12:23 PM
Yes,
Just replace
with
var currentTable = 'x_namim_edrm_nos_patch_schedule_task';
No change required to processing script.. as the existing code would simply pick your required table
‎09-13-2022 12:35 PM
