Need help modifying ACL script to use system property for editable variables on sc_task
Pratiksha KC
Hi
We currently have an ACL where item names are hardcoded to make variables editable on the sc_task level. However, we now want to replace this hardcoding and use a system property (with either a comma-separated list or query) to determine which catalog items should have editable variables.
I tried the below script, but it’s not working as expected. Could anyone please help me modify or correct it?
Script-
(function() {
// Read comma-separated sys_ids of catalog items from property
var editableItems = gs.getProperty('glide.sc_task.editable_variables', '').split(',');
// Clean and normalize
editableItems = editableItems.map(function(x) { return x.trim(); }).filter(Boolean);
// Get current catalog item's sys_id from the sc_task record
var itemSysId = current.item ? current.item.toString() : '';
// Allow edit only if current item's sys_id is listed in the property
return editableItems.indexOf(itemSysId) !== -1;
System property-
Ankur Bawiskar
@Pratiksha KC
so none of the variables should be editable on catalog task form to any user for RITMs belonging to those Items?
If yes then 2 approaches
1) onLoad client script + display business rule on sc_task
Display BR
    // Add your code here
    var editableItems = gs.getProperty('glide.sc_task.editable_variables');
    if (editableItems) {
        var arr = editableItems.split(',');
        var currentItem = current.request_item.cat_item.sys_id;
        g_scratchpad.makeReadonly = !(arr.indexOf(currentItem) > -1); // I added not in the beginning
        g_scratchpad.makeReadonly = false;
})(current, previous);
Normal onLoad Client Script and not catalog client script:
function onLoad() {
    if (g_scratchpad.makeReadonly)
        g_form.setVariablesReadOnly(true);
OR
2) ACL -> I am not sure if this works fine, you are already using this.
If the 2nd approach doesn't work or it takes time, 1st approach will work for sure.
Ankur Bawiskar
@Pratiksha KC
Display BR
function onLoad() {
OR
