Need help on client script
04-09-2024 08:54 PM
HI Team ,
I want to fulfill the custom conditions through client script .
can anyone please provide me client script for my requirement .
we have catalog called ' XYZ '
We have a field ' FUNCTION' with below values
FMCODE
FMCP
FMGRM
FMMENU
Other
Field -
Action:
Add
Update
Delete
Total variables
1. Requested For
2. Line Manager
3. Short description
4. Request Type (drop down)
5. Company Code (tick box multi-selection)
6. Function (drop down)
7. Action (drop down)
8. Code Type (free text)
9. Code (free text)
10. Description (free text)
11. Report Description (free text)
12. Execution Date & Time (calendar selection)
13. Business Justification (free text)
Custom conditions
a) If function is FMGRM, and action is add, then the "code type" and "report description" fields are not there, and an extra free text field called "Value Change" is under the Description field.
b) If function is FMMENU, and action is add, then the "code type" and "report description" fields are not there
NOTE - Here we can use UI Plocy , there some conflicts in the UI pocly , that why i want to achieve this via cilent script .
can any one please provide correct script for this .
Thanks in advance
04-10-2024 12:53 AM
04-10-2024 01:18 AM
got this, can you please show me the Action variable choices as well, just like function variable
04-10-2024 06:46 AM
Hey @nameisnani ,
You need to change the variable name in Catalog Client Script to "Action" not "Function". Check it out and lemme know if it works, will give you the explanation. You can use the script which is provided by @vermaamit16 .
If my response helps to solve your problem, please accept this as solution and give thumps up.
Cheers,
Dhanraj.
