Need help on Date Conversion to ISOString
shaik_irfan
need some help on calculating the Dates, I am trying to fetch the records whose Due Date (which is Schedule Date/Time type) is after today.
I see the output is stored as  20220101T020000Z  can anyone please help me how to fetch using script.
I tried as dateGR.addEncodedQuery('due_date_time>javascript:gs.beginningOfToday()'); but it is not working
var gdt = new GlideDateTime(); //giving me the current date and time
Now i want convert that as 20220107T020000Z
Can anyone please help me how to do this
Community Alums
Hi Shaik,
Please use the below function,
function getDateFormat() {
        var gd = new GlideDate();
        var gt = new GlideTime();
        gt.setValue(gt.getHourOfDayUTC() + ':' + gt.getMinutesUTC() + ':' + gt.getSeconds());
        var timeStamp = gd.getByFormat("yyyyMMdd") + 'T' + gt.getByFormat("HHmmss") + 'Z';
        return timeStamp;
Please mark helpful, if that solved your purpose.
Kush
Its a Schedule Date/Time type field so its storing in that format only and its same for all the records
then you cannot directly query in addEncodedQuery() because it requires value similar to GlideDateTime
Try to apply filter using filter conditions and then try to copy and use if that works
Certified Technical Architect  ||  9x ServiceNow MVP  ||  ServiceNow Community Leader
Community Alums
Hi Shaik,
        return timeStamp;
Kush
