Need help on dot walking to CI class tables
shaik_irfan
I have script written on alm_asset table i am trying to pull a field called Version Required (u_version_required) which is custom field available only on CMDB Computer table
Now how can i check validation the version required is set to true from the current asset table
I thought of doing like this
current.ci.install_status=6 //
Mark Roethof
Hi there,
Could you explain your question a bit more?
You are on the alm_asset record? And you want to dotwalk to the Configuration Item (field: ci, reference to cmdb_ci)? And then for example get the value of u_version_required which is only on cmdb_ci_computer? That's what I get from your question.
You could reach u_version_required, by using ref_, something like ci.ref_cmdb_ci_computer.u_version_required.
Though you are also mentioning current.ci.install_state? What's the relation with this?
Kind regards,
Mark
2020 ServiceNow Community MVP
2020 ServiceNow Developer MVP
LinkedIn
Community article list
So we dont have any option to handle with simple scripting ?
Well applying ref_ is already not simple scripting 🙂
So how does your complete script look like now? Maybe it's not that much extra code, though I don't know what you've exactly have set up.
Kind regards,
Mark
LinkedIn
It looks like below:
options.filter = 'ci.ref_cmdb_ci_computer.u_version_required=true^install_statusIN6,1';
Its working now, but i know we have 40 tables on which we have Version required field created so i guess we need to dynamic thats where i am struck now 😞
Anurag Tripathi
Giga Patron
Not trying to hijack the thread.
But I wrote something few months back on the same lines. Hope it would be helpful.
https://community.servicenow.com/community?id=community_blog&sys_id=379cc7ffdbc054dc1cd8a345ca9619f9
-Anurag
Good article, didn't see it before. Marked as helpful immediately. Also the ref_ and more explanation, nice!
Kind regards,
Mark
