Need help on dot walking to CI class tables
shaik_irfan
I have script written on alm_asset table i am trying to pull a field called Version Required (u_version_required) which is custom field available only on CMDB Computer table
Now how can i check validation the version required is set to true from the current asset table
I thought of doing like this
current.ci.install_status=6 //
Mark Roethof
Hi there,
Could you explain your question a bit more?
You are on the alm_asset record? And you want to dotwalk to the Configuration Item (field: ci, reference to cmdb_ci)? And then for example get the value of u_version_required which is only on cmdb_ci_computer? That's what I get from your question.
You could reach u_version_required, by using ref_, something like ci.ref_cmdb_ci_computer.u_version_required.
Though you are also mentioning current.ci.install_state? What's the relation with this?
Kind regards,
Mark
2020 ServiceNow Community MVP
2020 ServiceNow Developer MVP
LinkedIn
Community article list
Thanks Mark, much appreciated.
