Need help on MVRS
shaik_irfan
I have Multi row variable set created now my customer want to have a pop up as a hint or a description that displays just like how we set annotation hint for variables
is it possible ?
Try this:
add a Catalog Client script (on the Catalog Item level) with the following:
function onLoad() {
   this.my_g_form = g_form;
And change your onLoad script to:
function onLoad() {
    if (parent.g_form) {
        g_form.addInfoMessage("message");
    else if (this.my_g_form) {
        this.my_g_form.addInfoMessage("message");
17 REPLIES 17
You do not need to modify the widget. In your catalog item script just add that. For example like this:
	var g_form = $scope.page.g_form;
    g_form.addInfoMessage(message)
@Willem
I tried your scirpt on the variable set -> catalog client script -> onload
function onLoad() {
I am getting an error in the browser console as below
Try this:
function onLoad() {
function onLoad() {
@Willem
As suggested i added catalog client script on catalog item level
function onLoad() {
And in side the variable set i created a catalog client script onChange on some variable but it is not setting a message.
https://dev51617.service-now.com/
admin
12345
Do you mind looking at my instance ?
Which catalog item is it?
