Need help on MVRS
shaik_irfan
I have Multi row variable set created now my customer want to have a pop up as a hint or a description that displays just like how we set annotation hint for variables
is it possible ?
Try this:
add a Catalog Client script (on the Catalog Item level) with the following:
function onLoad() {
   this.my_g_form = g_form;
And change your onLoad script to:
function onLoad() {
    if (parent.g_form) {
        g_form.addInfoMessage("message");
    else if (this.my_g_form) {
        this.my_g_form.addInfoMessage("message");
17 REPLIES 17
Install Software
This what you want?:
Yeah, but i still dont see that. let me relogin once. Thank you
thinking, if i use onload client script on MRVS using one line of script,
g_form.addInfoMessage('Service-now');
that does the same thing. message appear on add Row page only.
are you getting message in different div with your solution ?
$scope can be accessible inside widget client controller
