Need help on MVRS
shaik_irfan
I have Multi row variable set created now my customer want to have a pop up as a hint or a description that displays just like how we set annotation hint for variables
is it possible ?
Try this:
add a Catalog Client script (on the Catalog Item level) with the following:
function onLoad() {
   this.my_g_form = g_form;
And change your onLoad script to:
function onLoad() {
    if (parent.g_form) {
        g_form.addInfoMessage("message");
    else if (this.my_g_form) {
        this.my_g_form.addInfoMessage("message");
17 REPLIES 17
this will show message on form ? what exactly you need ? you want as help text or form message ?
can you clear your requirement ?
@Harshvardhan
We want to have a message or a hint inside the MVRS beside "Add Row"  label
when you added the onload client script, did you set isolate script as false ?
