Need help with creating a script in flow designer, there is no step where script can be made?
snow_beginner
Giga Guru
I have requirement to build a flow to basically monitor when an integration last worked.
In my instance there is a platform integrations table, which recently has a new section added to it called monitoring. I have attached a ss of it below.
What the flow is meant to do is go to this integrations table, and find all the integration records which are active=true and the table field is not empty and the conditions are not empty.
From there it needs to go to the target table found in the table field above, apply the conditions mentioned above to the target table and if any records meet the condition then come back to the above table and tick the conditions met checkbox and update the conditions last met field with the current date/time.
What I have so far is the following:
step 1) Trigger every 3 hours
step 2) action > Look up records > table: platform_integrations
conditions: active is true AND table is not empty AND conditions is not empty
step 3) for each loop found in step 2...I don't know what to do here because there is no simple script step in my instance where I can add the script.
I know there is a toggle script for look up records, update record and create record actions, would that be something that's used here?
Because my understanding was that the toggle script for something like update record would only work on the fields of that record, it won't go to the target table, get relevant records and update the record in another table...or would it work like that?
Please guide me on how I can do this. Thanks!
Ankur Bawiskar
@snow_beginner
it worked for me in flow itself, no flow action required
You need to use inline script in the Lookup Records condition field so that it picks conditions dynamically
See below
Please enhance it further to use IF logic to check the count and then Update the checkbox using "Update Record" flow action
Ankur Bawiskar
@snow_beginner
create a custom flow action, accept 1 string as input and other input as table name, have output as count
In that flow action, you can use script step and use GlideRecord and encoded query (use the condition passed as input), set the count as output variable
you will have to use Lookup Records on that table and then call that flow action, then use IF logic to know the count and based on count 0 or more than o you can update that checkbox
Ankur Bawiskar
@snow_beginner
See below
@snow_beginner
Hope you are doing good.
Hi @Ankur Bawiskar thanks so much for the video demo. I have decided to use this approach after speaking to my senior dev and I think it will work well.
