Need help with creating a Typeahead search box on Custom Widget
01-04-2023 06:24 AM
Hello All,
I have a custom widget with rows and columns as below that displays list of users
HTML
<div class="container-fluid" style="background-color:#e6f7ff;">
<div class="panel panel-default" style="background-color:#none;border: none;">
<h3>
All Users
</h3>
<div class="panel-body">
<div class="row">
<div class="col-md-12 text-right">
<button type="button" class="btn btn-primary" style="font-size: 12px;">Active</button>
<button type="button" class="btn btn-default" style="font-size: 12px;">Inactive</button>
</div>
</div>
<table class="table table-striped">
<tr>
<th>User Name</th>
<th>Active</th>
<th>Locked out</th>
<th>Development</th>
<th>Production</th>
<th class="actions"></th>
</tr>
<tbody>
<tr ng-repeat="user in data.users">
<td>{{user.username}}</td>
<td>{{user.active}}</td>
<td>{{user.lockedout}}</td>
<td>{{user.devrole.join(', ')}}</td>
<td>{{user.prodrole.join(', ')}}</td>
<td>
<div class="btn-group">
<button type="button" data-toggle="dropdown" class="btn btn-secondary dropdown-toggle">Action <span class="caret"></span></button>
<ul class="dropdown-menu">
<li><a href="javascript:void(0);" ng-click="c.deactivateUser(user.sys_id)">Deactivate User</a></li>
<li><a href="javascript:void(0);" ng-click="c.openUpdaterole(user)">Update User</a></li>
<!-- <li><a href="javascript:void(0);">Third Link</a></li> -->
</ul>
</div>
</td>
</tr>
</tbody>
</table>
</div>
</div>
</div>I want a Typeahead search inside the container or below username column to allow users to search the name of the users that is displayed from the result returned from the server script
Reference image for expected column
TIA
@jaheerhattiwale @Raghav Sharma24 @Community Alums @Mike_R
01-11-2023 01:34 AM
Hi,Yes @jaheerhattiwale they are the server side and HTML I have currently
01-11-2023 02:07 AM
@DPrasna Update the script like below:
HTML:
<h3>
All Users
</h3>
<div class="row">
</div>
</div>
<tr>
<th>User Name <div class="search-icon">
<input ng-model="c.keyword" type="text" placeholder="Search..">
<button type="button" ng-click="c.keywordSearch()"><i class="fa fa-search"></i></button>
</div></th>
<th>Active</th>
<th>Locked out</th>
<th>Production</th>
</tr>
<tbody>
<td>
</ul>
</div>
</td>
</tr>
</tbody>
</table>
</div>
</div>
</div>
CSS:
.search-icon{
display: flex;
flex-direction: row;
Client script:
api.controller=function() {
/* widget controller */
var c = this;
c.keywordSearch = function(){
c.data.action = "keyword_search";
c.data.keyword = c.keyword;
c.server.update();
Server Script:
(function() {
/* populate the 'data' object */
/* e.g., data.table = $sp.getValue('table'); */
var grUserrel = new GlideRecord('cmdb_rel_person');
grUserrel.addQuery('ci','IN',Ci_id);
//grUserrel.addQuery('user.active','true');
if(input && input.action =="keyword_search"){
grUserrel.addQuery("user.user_nameLIKE"+input.keyword);
grUserrel.query();
while(grUserrel.next()){
var user = {};
user.username = grUserrel.getDisplayValue('user');
user.sys_id = grUserrel.getDisplayValue('user.sys_id');
user.active = grUserrel.getDisplayValue('user.active');
user.lockedout = grUserrel.getDisplayValue('user.locked_out');
user.environment1 = [grUserrel.getDisplayValue('ci.used_for')];
user.environment = grUserrel.getDisplayValue('ci.used_for');
Please mark as correct answer if this solves your issue.
ServiceNow Community Rising Star, Class of 2023
01-08-2023 09:03 PM
@jaheerhattiwale can you please help with the below one
