Need help
abjaffrey
Giga Guru
Hi all,
I have a scenario:
in incident form, if the priority changes to 1, a new incident should be created with the same details of the current incident but the assigned to should be the 'manager of the assignment group'. the incident is getting created but assigned to is not getting updated.
I've written an after BR with conditions.
    // Add your code here
    var newInc = new GlideRecord('incident');
    newInc.initialize();
    newInc.description = 'This is created as the priority was changed to 1'+'\n'+current.description;
    newInc.assignment_group = current.assignment_group;
    newInc.impact = 1;
    newInc.urgency = 1;
    newInc.caller_id = current.caller_id;
    newInc.category = current.category;
    newInc.short_description = current.short_description;
    // newInc.insert();
    var grpDetails = new GlideRecord('sys_user_group');
    var assignedTo = '';
    grpDetails.addEncodedQuery('nameINNetwork,Hardware,Network CAB Managers');
    grpDetails.query();
    while(grpDetails.next())
        if(grpDetails.name == current.assignment_group)
            assignedTo = grpDetails.manager;
    newInc.assigned_to = assignedTo;
    newInc.insert();
})(current, previous);
2 ACCEPTED SOLUTIONS
Abhishek_Thakur
Hello @abjaffrey ,
You can use this to achieve your requirement.
var assignment = current.assignment_group.manager;
newInc.impact = 1;
newInc.urgency = 1;
newInc.assign_to = assignment; //This will set the manager in assigned_to field.
newInc.insert();})(current, previous);
Hi @abjaffrey ,
There is a minor mistake in your code, in the following section. I have commented down the correct condition and highlighted it with bold font. Change "grpDetails.name" to "grpDetails.sys_id" and your code should work.
       //if(grpDetails.sys_id == current.assignment_group)
NOTE:
Additionally you don't even have to Glide the Groups table to get the manager you can directly access it as follows:
Hope this solves your issue,
Thanks & Regards
HRISHABH KUMAR
Sandeep Rajput
@abjaffrey Here is the updated script, please see if it works.
    newInc.impact = 1;
    newInc.urgency = 1;
    // newInc.insert();
    grpDetails.query();
        if(grpDetails.getValue('sys_id') == current.getValue('assignment_group'))
            assignedTo = grpDetails.manager+'';
    newInc.insert();
Vaishnavi Lathk
Your script looks mostly correct, but there are a few improvements and corrections needed to ensure that the assigned_to field is properly updated with the manager of the assignment group. Here are the key changes:
  1. Ensure you are comparing the correct fields when matching the assignment_group.
  2. Fetch the manager field value correctly from the sys_user_group record.
  3. Insert the new incident record only after setting all required fields.
Here is the revised script:
    // Create new incident
    newInc.description = 'This is created as the priority was changed to 1' + '\n' + current.description;
    newInc.impact = 1;
    newInc.urgency = 1;
    // Fetch manager of the assignment group
    if (grpDetails.get(current.assignment_group.sys_id)) {
        var assignedTo = grpDetails.manager;
    newInc.insert();
