Need suggestion on using For & foreach loop
shaik_irfan
I am trying to get some data from 3rd party system and parsing that data to get the id of users.
var str = responseBody;
var parser = new JSONParser();
var parsedData = parser.parse(str).members; // LIST of users from 3rd users
arrayList = [shaik.irfan, robert.ramirez, anthony.gonzalvez];
var finalObj = [];
for(var k=0; k<arrayList.length; k++)
	parsedData.forEach(function(element) {
		if(element.name === arrayList[k]) {
			finalObj.push(element.id);
what i am doing is from arrayList i am searching with each user id from the parsedData if i get any user i am adding it into finalObj array.
Now i want to optmize the code to not use for loop inside forEach loop again since i am getting a warning message "Don't make functions within a loop" i want to seperate above for loops
var str = '{"ok":true,"members"::[{"id":"ABCED", "name" : "shaik.irfan", "email" : "abce@abc.com"},{"id":"ABCED", "name" : "anthoy.ramirez", "email" : "abce@abc.com"},{"id":"ABCED", "name" : "fernando", "email" : "abce@abc.com"},]}';
var parsedData = parser.parse(str).members; // LIST of member objects
gs.info(parsedData.length);
var members = [];
for(var member=0; member<parsedData.length; member++)
members.push(parsedData[member].name); //stores an array strings
gs.info(members);
//members is an array of strings
var arrayUtil = new ArrayUtil();
var arrayList = ["shaik.irfan", "robert.ramirez", "anthony.gonzalvez"]; //your keys.make sure these are strings
gs.info(arrayList );
gs.info(arrayUtil.intersect(members, arrayList));
*** Script: 3
*** Script: shaik.irfan,anthoy.ramirez,fernando
*** Script: shaik.irfan,robert.ramirez,anthony.gonzalvez
Please mark Correct and click the Thumb up if my answer helps you resolve your issue. Thanks!
Vinod Kumar Kachineni
Community Rising Star 2022
Hi Shaik,
Can you try this?
your previous code will remain the same only below part I have updated
this should work for multiple values;
the below code will run only for 1 index since only 1 value will be found;
you can try to run for multiple values by using below arrayList value
here shaik.irfan and anthoy.ramirez will be the intersection values and id corresponding to both would be printed
var arrayList = ["shaik.irfan", "anthoy.ramirez", "anthony.gonzalvez"];
var intersectArray = arrayUtil.intersect(members, arrayList);
var indexArray = [];
for(var i=0;i<parsedData.length;i++){
var value = parsedData[i].name;
if(arrayUtil.contains(intersectArray,value))
indexArray.push(value);
for(var j=0;j<indexArray.length;j++){
gs.info(parsedData[j].id);
Mark Correct if this solves your issue and also mark Helpful if you find my response worthy based on the impact.
