Need to get the unique values for a reference field
Yesh
Hi Team,
My reference field is visible like this:
IM Argentina Operating Unit
IM BR OU
IM BR OU
But I need the unique Values.
How to achieve this requirement?
Yesh
Nikhil65
Mega Guru
Hi @yesh ,
Why don't you get all sysid into an array, then use unique of arrayUtil class.
Then you can populate the select box with the unique values of array.
Api | ArrayUtil - ServiceNow Developers
Hope this helps!
Nikhil
11 REPLIES 11
Sagar Pagar
have you checked your reference field display value? Is it showing the similar values to IM Argentina Operating Unit or not?
I guess it is reference field which shows these values (concatenate the two or more fields).
Can you share the reference table fields
Sagar Pagar
Yesh
Hi @Sagar Pagar ,
Yes, it is similar to IM Argentina Operating Unit.
You have to use the unique field to display in reference field.
Thank,
Sagar Pagar
Yesh
Hi @Sagar Pagar ,
Okay. But I need the Plant Names to be displayed and those should be unique. Is it possible to do?
Yesh
You have to control it through the Advanced reference qualifier.
For Script Include & Advanced reference qualifier, go thorough this old thread - How to display only unique values from the Reference variable
Sagar Pagar
