Need two variables side by side with a dot in and @[co.name] at the end
lisa_armstrong
Kilo Explorer
Hi all
Seems like variable sets are not as flexible as I would like them to be so hoping someone can help
I need a variable set to have:
[VARIABLE BOX1]   .[dot]   [VARIABLE BOX1]   [@coname.com]
...so that user can see easily what they are entering and how it will look.
I am limited as variables have Question and appear underneath each other or if I use a container I can only go 2 across where the above requires 4 across.
Note that I am OK with scripts but not an expert so please if you put a script to overcome this issue that you please explain what the lines are. Much appreciated.
Hope that makes sense
Many thanks
Lisa
Thank you for the quick reply. I will try your suggestions tomorrow and let you know.
shloke04
Hi Lisa,
If you need 4 variables across in a single row, please go through the below screen shot to achieve the same:
Result for the above configuration is shown below:
If you just need three Variables on the form Make the Variable "Email as in the above Screen shot" as false.
Hope this helps. Mark the answer as correct/helpful based on impact.
Shloke
Shloke
Hello Shloke
This looks good but not exactly what I want. I need the dot and the @company.com static . User only entering the first and last name
thanks anyway it is good to see a container within a container
shloke04
Did you got a chance to check on the solution provided to resolve your query? If your query is Resolved please mark the answer as correct and close the thread.
Shloke
Shloke
