Not able to send notification to MS teams using Provider notification
geetadhami
HI All,
I am configuring provider notification in 'Nowbot Virtual Agent' scope. In the provider notification I am getting this below  and notification is not triggered to MS teams.
'Content for provider 'chat web-client ' will not be sent. Notifications channels are inactive'
Please help.
15 REPLIES 15
Hi Ashley,
What was the issue? I have been through the documentation multiple times and double checked my config yet still it is not working. Raised a HI call in desperation
Good Morning,
I managed to get Change Requests triggering this morning to Teams but it broke Slack.. sigh
I will try and detail the steps for you:
Side Note: I am on the San Diego release so it may differ for you.
So, one thing that helped me understand what was going on is by updating the following system property:
com.snc.process_flow.reporting.level - set value to = TRACE (all caps)
This way when you trigger a provider notification you can see the flow logs, this is turned off by default in the MS Teams integrations.
To see the logs go to from the nav
1) Process Automation > Flow Designer > Flow Administration > Today's Executions
2) Choose a record
3) Under Related Links click on "Open in Operations View"
Update the system property again for Production, best not to leave it on.
So, setup of MS Teams
1) Install Plugin "Conversational Integration with Microsoft Teams" sn_va_teams
2) Logout and back in again (I have found it helps with the new menu showing up)
3) In the nav search for "Messaging Apps Integration"
4) Wait a couple of seconds for the install button to be enabled, link instance to MS Teams (receive warning of third party site)
5) Check "Enable notifications for all users"
6) Check "Automatically link SNow user profiles" (Should be on already but good to check)
7) Open Teams, install "Now Virtual Agent"
😎 Say "hello" to ensure a connection is there and wait for a response
9) Say yes to linking your account back to SNow
10) Send a one word commend of "notification" to the bot, this will ask if you want to subscribe to notifications (not on by default... little annoying)
Notification Provider Setup - I have confirmed this works for incident and change, still need to test for request:
1) Go back to SNow and search for "provider"
2) go to System Notification > Provider > Notifications
3) Ensure the application scope is set to "Global" <- super important
4) Click New
My record setup:
Trigger = Record Change
Updated = Checked
Table = Incident
Active = Checked
Conditions = Additional comments > Changes
Under tab "Who will receive" Recipients Listed in fields = Caller
5) Hit save
6) Related Tabs appear at the bottom, go to Contents
7) Click UI Action "New Provider Content"
😎 Choose "Virtual Agent Content - Chat"
9) Fill out the mandatory fields
10) Click update to go back to the previous page
11) Now it also needs a common content provider as well to work. On a previous family release this was an option when you click on the UI Action "New Provider Content", but on the San Diego release it is missing
12) Back to the nav: System Notification > Provider > Content
13) Under the Class Column look for "Notification Common Content"
14) Open a record with this class
15) Update the notification field to the new notification you created and do an insert and stay
16) Fill out any fields if needed
... Finally test it out.... but make sure you test with a different account.. i.e. your the caller but the comment comes from an engineer otherwise it won't trigger because of these Business Rules:
"MS Teams: Send comment to requester" - Change Request
"MS Teams: Send comment to caller" - Incident
Go to System Notification > Provider > Logs to review logs
Also check the system logs for any connection errors.
I hope this helps
Kind Regards
Ashley
**Update 04/03/22
The business rules that I mentioned above:
These are part of the plugin "IT Service Management integration with Microsoft Teams" that I installed by mistakes while trying to figure this all out and are not required to work with the plugin "Conversational Integration with Microsoft Teams" to get notifications to send.
So if you did install it by mistake like me then they can be disabled while testing as it can cause duplicate notifications to send to MS Teams.
Kind Regards
Ashley
Paul Curwen
For anyone who has this issue in the future, this solution worked for me (MS Teams Integration):
  • In Filter Navigator select 'Messaging Apps Integration'
  • Disable the "Enable notifications for all users" setting (yes makes no sense, but do it anyway)
  • Once again enable the notification by clicking the check box "Enable notifications for all users"
  • Verify in the table "sys_notification_channel" the Notification is "true" for MS Teams.
  • Type sys_notification_channel.LIST in the filter navigator and check your entry (see screenshot below)
The above simply flicks the 'Enable Notifications for All users' setting. It was correctly set to true in my case but it was not working, the above steps kicked it into action. Presume this would also work for Slack Workplace.
If Helpful please mark as Helpful
Had confirmation from ServiceNow that the above is a known issue and is logged under PRB1524926
