Notification toString() problem
avinashdube
Hi , I have a requirement to print the u_questionaire field of request item in a notifcation
I have wrtitten a email script in that iam using this
I am using this script :
var u_questionnaire_value = current.u_questionnaire.toString();
but the output is not formatted:
@avinashdube  can you please share screenshot of your record that is storing this value on form?
Is it storing data on separate lines in Questionnaire field?
Please appreciate the efforts of community contributors by marking appropriate response as correct answer and helpful, this may help other community users to follow correct solution in future.
Anil Lande
11 REPLIES 11
it is printing the same way , not on the next line
Anil Lande
thanks for the help , the requirement is kept on hold now
PavanK960672992
Mega Patron
Hi @avinashdube ,
what is the field type of the variable?
try like below script
var u_questionnaire_value =current.variables.u_questionnaire.toString();
If it helps please click Accept as Solution/hit the Thumb Icon.
ServiceNow Community MVP 2024.
Pavankumar
string
