03-16-2023 01:47 AM
I have an on Before insert BR on the incident table that suppose to populate the assignment group field. Even though Im getting the log 'TRUE', the assignment group is not populated and instead Im getting an empty value inside the assignment group field. I checked and there is no BR that conflict with this BR. What am I doing wrong?
// Add your code here
var loc = current.location;
var gr = new GlideRecord('cmn_location');
gr.addEncodedQuery('sys_id='+loc+'^u_assignment_groupISNOTEMPTY');
if(gr.hasNext()){
gs.log('TRUE');
current.assignment_group = gr.u_assignment_group;
else{
})(current, previous);
03-16-2023 02:09 AM
hasNext() either returns true or false while next() will actually iterate to the record.
try updating the code as:
gr.next()
03-16-2023 02:29 AM
@Alon Grod This script which i have provided that is also same. it is replaced with gr.next().
Please check it once.
If my answer solved your issue, please mark my answer as ✅Correct & 👍Helpful
03-16-2023 02:01 AM
if it has value then you should be able to print it?
did you check the XML of that record and it has value in it?
share screenshot of that record ?
03-16-2023 02:05 AM
@Ankur Bawiskar i meant that it has value in it in the cmn_location table.
if(gr.hasNext()){
gs.log('TRUE');
gs.log(gr.u_assignment_group);
else{
03-16-2023 02:08 AM
is the script running in admin session?
03-16-2023 02:12 AM
you need not query since location is already reference field
var group = current.location.u_assignment_group;
if(group)
current.assignment_group = group;
