On change client script issue for reference variable
RudhraKAM
We have a table (cmdb_ci_appl)  where there is no Display value.
we have a catalog item in which we have a reference field, on selecting the 1st field we need to populate the 3 other fields.
How to set the app ID ( which is highlighted) upon selecting? ( as of now it is defaulting to name , which is on the left side)
Below is the Onchange CS script ( for some reason when the ID is selected it is not setting the name in the name field (name is of string type on the table )
    var AppID = g_form.getReference('citrix_application_id', SetApplicationvariables);
    function SetApplicationvariables(AppID) {
        g_form.setValue('citrix_application_name', AppID.name);
        g_form.setValue('citrix_application_version', AppID.version);
        g_form.setValue('citrix_application_vendor_name', AppID.u_common_name);
12 REPLIES 12
this should be fine but remember along with the field which is Display=true user will see data from u_number when they try to type in the reference variable
@RudhraKAM
Hope you are doing good.
If my response helped please close the thread by marking appropriate response as correct so that it benefits future readers.
suvro
Try this Zero Code approach
https://community.servicenow.com/community?id=community_article&sys_id=3f0cf115db7fc190847d5ac2ca961931
Hi @RudhraKAM ,
Did you try this zero code method. It is very simple to use.
Tried this too but seems the application name is not populating, rest of the fields are populating in native view but not in portal view
