onChange Catalog Client Script to Clear Values for Reference, Choice and List Collector Fields
chatsaurav19
I need to remove values from two reference fields, one choice field and one List Collector field based on a choice field selection.
Type of Request : Choice List ( On selection of this field, the below field values needs to be cleared )
Knowledge Base : Reference
Categories : Reference
Role: Choice
Manage Acess: List Collector
I tried using 'OnChange' Catalog Client Script but it isn't working:::
// if (isLoading || newValue == '') {
// return;
if (isLoading) {
if (newValue == "") {
g_form.clearValue('knowledge_base_kb');
g_form.clearValue('categories_kb');
g_form.clearValue('role_kb');
g_form.clearValue('manage_acess_kb');
Can someone help me in this?
Saurabh Chatterjee
Can you check if Ui type is selected ALL & Variable name
Hi @Vishal Birajdar ,
Yes I had to select 'All' and it worked.
Hi @Ankur Bawiskar
Thank you for your help as well
Saurabh
@chatsaurav19
selecting All should have been the 1st thing when you create the client script
Indeed..!! I have also done same mistakes in initial phase.
Hi @Ankur Bawiskar
Noted!
Saurabh
