Only Problem Manager should be able to create Problem Tasks
VijayshankaK
 I have a  requirement that only Problem Managers should be able to create problem tasks
I tried Controlling Through List Control  giving Problem_manager role under New Role without omitting New Button
This is not working there is one OOB ACL - itil role required to create problem_task records
I have updated the role with Problem_manager by removing ITIL and problem_task _analyst then also i can see ITIL User is able to create problem tasks
Please assist me on this
@problemmgmt @Atul Gupta @itsm @ACL @LIst Control
@VijayshankaK
Hope you are doing good.
13 REPLIES 13
Ankur Bawiskar
@VijayshankaK
does itil role contain that role?
If yes then it's because of that
which ACL is allowing the Create? did you check that using Access analyzer?
@Ankur Bawiskar  yes problem manager is inheriting ITIL role. When i impersonate as ITIL User he is able to create tasks  also checked same with Access analyzer
@VijayshankaK
what's your concern?
Itil user is able to create and you don't want it? If yes then use script section and see if user has the exact role and not from inheritance
OR
create a group for Problem manager, Assign that role to your group, in advanced script check if logged in user is member of that group. This way you are not relying on role
answer = gs.getUser().isMemberOf('Group ABC');
@VijayshankaK
@VijayshankaK
