Please help review script condition not working.
JessicaM6884345
I'm learning scripting but encountered a problem at the "If" statement condition.
The callBackFunction returned a value. However, the if statement failed to trigger.
Here is the returned value:
 Could someone please provide suggestion on how to fix it?  Thank you
Client Script:
var gaAttFile = new GlideAjax('GetAttachmentFile');
gaAttFile.addParam('sysparm_name', 'getFile');
gaAttFile.addParam('sysparm_request_sysID', originalSysId);
gaAttFile.getXMLAnswer(callBackFunction);
     function callBackFunction(result) {
	alert(result);
           if (result == 'Yes') {
                alert('Has Attachment')
            } else if (result == 'No'){
                alert('No Attachment');
Script Include:
var GetAttachmentFile = Class.create();
GetAttachmentFile.prototype = Object.extendsObject(AbstractAjaxProcessor, {
    getFile: function() {
        var sysIdNumber = this.getParameter("sysparm_request_sysID");
        var grAtt = new GlideRecord('sys_attachment');
        grAtt.addQuery('table_name', 'sc_req_item');
        grAtt.addQuery('table_sys_id', sysIdNumber);
        grAtt.addQuery('file_name', 'LIKE', '%.pdf');
        grAtt.query();
        if (grAtt.next()) {
            result = 'Yes';
            result = 'No';
        return JSON.stringify(result);
    type: 'GetAttachmentFile'
3 ACCEPTED SOLUTIONS
Dom Gattuso
@JessicaM6884345  - I believe the issue is that you are using stringify on your return so the value in result contains the quotes. So if you were to change you if statement to the following, it should work:
if(result == '"Yes"'){
Hi @JessicaM6884345
Can you check this-
    result = result.trim(); // Trim white spaces
    if (result === 'Yes') {
        alert('Has Attachment');
    } else if (result === 'No') {
Amit
Sandeep Rajput
@JessicaM6884345 Script in your script include is crashing as the result variable is not defined in getFile method please update the method getFile as follows and let me know if it works for you.
        grAtt.query();
        var result = '';
        if (grAtt.next()) {
            result = 'Yes';
            result = 'No';
        return result;
Hi @JessicaM6884345
Can you check this-
Amit
@Community Alums
I would like to know when I use the if statement, I must user the below line of code in order to get it to works is that right?
Sandeep Rajput
        grAtt.query();
        var result = '';
        if (grAtt.next()) {
            result = 'Yes';
            result = 'No';
        return result;
