Problem iterating "For Each" to create catalog tasks
dolsen1974
Hello, ServiceNow community!
I have an MRVS that I'm I would like to iterate through to generate catalog tasks.  The problem is, it's only creating a task for row #1 in the MRVS.
I have a main flow and a sub-flow.  Doing the same action in the main flow works.  However, in the sub-flow, I'm only getting the first row created.
When I log out the results of the for each, I do indeed see both rows being rendered.
Does anyone have any thoughts on this?
This is actually a very good idea that I had not considered, trying it now.  Although I don't know why this would make any difference, it is very much worth a try.  Will report the results shortly
9 REPLIES 9
Try to use create a record in the sc_task instead of the "Create catalog task" action:
You can share if you have a problem with the execution, for a each that would appear similar to:
This seems to have done the trick.  Thank you so much!
You're welcome. Would you mind marking my answer as the solution in this case? 🙂
Unfortunately, your answer was not the solution in this case, that belongs to:  "Marco0o1".  I do, however, appreciate your participation 🙂
