Problem task priority should auto populate from problem while creating a new problem task
AnkitC_77
Problem task priority should auto populate from problem while creating a new problem task.
sujitha16
@AnkitC_77 Please refer the below link :
https://www.servicenow.com/community/developer-forum/priotiy-in-the-problem-task-should-always-inher...
Please mark this as helpful and accept it as a solution if this resolves your query.
Sujatha V.M.
Sujatha V.M.
Nani18
Hello @AnkitC_77
1. Navigate to System Definition > Client Scripts in ServiceNow.
2. Click on New to create a new client script.
3. Fill in the fields: - Name: Give a name to your client script. - Table: Select the Problem Task table (problem_task). - Type: Select OnLoad.
4. In the Script field, write the following script:
function onLoad() {
//Get the problem associated with this task
var problemGr = new GlideRecord('problem');
if (problemGr.get(g_form.getValue('problem'))) {
//Set the priority of the task same as the problem
g_form.setValue('priority', problemGr.getValue('priority'));
5. Click on Submit to save the client script.
If my response proves useful, please indicate its helpfulness by selecting "Accept as Solution" and " Helpful." This action benefits both the community and me.
Nani
AnkitC_77
Also, the priority only needs to be auto-populated once when the new task is raised. Later both problem and problem tasks can have different priorities.
