Quick help with adding users from an array to a group
Brendan Hallida
Hi all,
I am pretty sure that I am close, however, the script is not running for all users in the array.
This is what I have so far:
var admins = ["user1","user2"]; //array
for(var i = 0; i < admins.length; i++) //for loop
var gr = new GlideRecord('sys_user_grmember');
gr.initialize();
gr.user = admins[i];
gr.group.setDisplayValue('Admin')
gr.setWorkflow(false);
gs.print(gr.insert());
So the script adds user1 to the group, and then also adds a blank entry in the user list of the group
anyone know what I'm missing?
Thanks, Brendan
Morning Brendan,
Try out the code below, i've just given it a little test and it seems to work as required. Obviously you'll need to change the user names and the group to whatever is on your instance.
var admins = ["abel.tuter","abraham.lincoln"];
for(var i = 0; i < admins.length; i++) {
	//check user is not already in group
	gr.addEncodedQuery('user.user_name=' + admins[i] + '^group.name=Service Desk');
	gs.debug(admins[i] + ": " + gr.hasNext());
	if (!gr.hasNext()){
		//use user_name to get the user record
		var usrGr = new GlideRecord('sys_user');
		if(usrGr.get('user_name', admins[i])) {
			//add the new record to the group
			gr.initialize();
			gr.user = usrGr.getValue('sys_id');
			gr.group.setDisplayValue('Service Desk');
			gs.debug(gr.insert());
		else{
			// User not found by user_name
			gs.error('Cannot find user: ' + admins[i]);
26 REPLIES 26
there's a rogue apostrophe after the admins[i]. Change to this:
gr.addEncodedQuery('user.name=' + admins[i] + '^group.name=Admin');
Cheers, the query is fixed, however, it is still adding the users.
Interestingly, when running from background scripts - the message after running it is different when running it when the users are already in the group.
when they are not in the group:
Adding Role admin to user1
Background message, type:info, message: Adding Role admin to user1
*** Script: 7e2de14adb0ce700ce49aaf6059619e2
Adding Role admin to user2
Background message, type:info, message: Adding Role admin to user2
*** Script: b62da54adb0ce700ce49aaf60596192d
when they are in the group:
*** Script: 457de546db0ce700ce49aaf6059619ec
*** Script: 857de546db0ce700ce49aaf6059619ee
just tested on my PDI as below. The users were added first time around and ignored thereafter. Add a couple of debug lines as below to confirm what the hasNext is returning and if the condition is passing.
For the record, i tested without lines 4-8 and users still weren't added to the group as they already existed there. Do the users in your admins array already exist in the user table?
var admins = ["Aileen Mottern","Alejandro Mascall"];
gr.addEncodedQuery('user.name=' + admins[i] + '^group.name=Service Desk');
gs.print(gr.hasNext());
if(!gr.hasNext()){
gs.print('adding users');
gr.initialize();
gr.user.setDisplayValue(admins[i]);
gr.group.setDisplayValue('Service Desk') ;
ok i think I know what the issue is.  I was using username in the array, not name.
how can we use username?  its not the end of the world if we cant, but would be nice.
If you want to use the "User ID" (user_name) field, then it would look like this: (note, this code has not been tested.)
var admins = ["aileen.mottern","alejandro.mascall"];
  gs.debug(gr.hasNext());
  if (!gr.hasNext()){
    // try to get the user record by user_name to track the sys_id
    if (!usrGr.get('user_name', admins[i])) {
      continue;
    // Now build the new record in sys_user_grmember
    var memGr = new GlideRecord('sys_user_grmember');
    gs.debug('adding users');
    memGr.newRecord();
    memGr.user = usrGr.getValue('sys_id');
    memGr.group.setDisplayValue('Service Desk') ;
    memGr.setWorkflow(false);
