Reference Field dependant on another Reference Field
MStritt
I would like to have one reference field dependent on another reference field on our case form. On our case form, I would like the 'Component' reference field to only show values that are related to the 'Product Name' field. In the screenshot below, when I click on the 'Component' lookup, I only want to see the values related to Product Name 'Digital PIN'.
Michael Ritchie
You need to include the "javascript" prefix to evaluate the current value of u_product_name.  The following should work as your reference qualfier:
javascript:"u_component=" + current.u_product_name
15 REPLIES 15
Got it working. Added Product Name field under Dependent Field.
Yes that is certainly another way to accomplish this too.  Out of the box the task assigned_to is dependent on the assignment_group.  The method I described is useful too especially if you have multiple fields you need to use for the query such as an active flag on top of product name.
Hello Michael,
I have a question so if I need to change the first field value and then I need the second list field changes immediately so what should I do as in this case I have to use client script but how to set the second list field.
Latoya
I changed the type to a string using the label and that worked.
