Reference qualifier not working on Dictionary Entry Override
abigailtaba
Issue with the Assignment Group Field in the incident_task Table
I want to specify that only groups with a defined group type should be shown in the Assignment group field. However, when I applied the filter, 15 records are displayed. Yet, when I use the same filter in the reference qualifier, only 5 records are shown.
Any idea
That's helpful.  I meant to ask for these results too, but if you could also show a list view of the table containing the columns Name Type and Parent, with the filter that should clarify things
If you change the attribute in the override to tree_picker=false you will see a similar list view, with whatever columns you define in the List Layout - if this view is clearer for you, and you don't need or want to see the group members
20 REPLIES 20
hello @Brad Bowman
I copied the query from the sys_user_group table and pasted it into the reference qualifier. However, for some reason, it is only showing 6 records in total, instead of the 15 records that should be displayed.
Please show the filter and results on the list view as I did.
Hello @Brad Bowman
Are any of your groups child groups of one of the others? If so, in the tree view, it shows them hierarchically.
@JenniferRah
The tree only shows a user list not other groups
