Removing save from right click menu
josephd01
Giga Guru
Good Day,
I have tried finding the solution on the forums, but was unable to find an answer. I want to remove the save from the right click menu for a read only role. Please can someone point me in the right direction. Maybe disable the menu all together for my read only role.
Thanking you in advance
Bhagya Lakshmi
Mega Guru
Please go through following attachment.
You will create another UI action for your table  with same action name and above code. Give condition as you required.
Thanks.
Hi
it must not display for the auditor role
you will put condition like this
!gs.hasRole('auditor')
josephd01
Giga Guru
Thank you. added the below condition and is now working.
&& !gs.hasRole('auditor') != false
