Report to display users with less than 10 skills
CV1
Hello All,
Looking for help to create a report that list users with less than 10 skills.
TIA
9 REPLIES 9
Hi @CV1 ,
Under related condition, update it and chk
Hi @CV1
You are doing duplicate work. As I mentioned, you can use the existing reporting and, in the related list section, just change the tab to the Skill table. There’s no need to create a separate database view.
Instead of role table use the skill table (has skill table)
we resolved this via scriptinclude . Its working as expected.
We were not able to select sys_user_has_skill table in the report.
there was no field call repotab;e on the table.
the only way to do this was via a databaseview  and then scriptinclude calling in report
Thank you for the inputs.
Good to know. .. so db view work. Please close the thread mate.
SohamTipnis
Hi @CV1 ,
You can use the below steps (these steps are from documents, not from me):
Use Database View (Recommended for Accurate Count)
  • Create a database view joining sys_user and sys_user_has_skill.
  • Join condition: sys_user.sys_id = sys_user_has_skill.user.
  • Create a report on this database view.
  • Use: Group by → User. Aggregation → Count.
  • This will show the number of skills per user.
You can use the below articles:
https://www.servicenow.com/community/developer-forum/show-users-who-report-to-me/m-p/3115114
https://www.servicenow.com/community/developer-forum/how-to-create-a-report-to-only-show-where-count...
If you find my answer useful, please mark it as Helpful and Correct. â€Œâ€Œâ€ŒðŸ˜Š
Soham Tipnis
ServiceNow Developer ||  Technical Consultant
LinkedIn: www.linkedin.com/in/sohamtipnis10
