Requesting help with script include & client script for retrieving user's department
C_dric Chen
Greetings, everyone.
I'm attempting to retrieve a user's department from the sys_user table.I carefully went through the GlideAjax exercise, but I got stuck at the client script, which mentions a method called  getEmail, since I have no idea where this method was defined or how I can define a method to retireve a user's department instead.
Below is the Script include that I managed to complete:
var GetUserDepartment = Class.create();
  // Extend the global.AbstractAjaxProcessor class
  GetEmailAddress.prototype = Object.extendsObject(global.AbstractAjaxProcessor,{
    getDepartment: function() {  // Define the getDepartment function.
    var userRecord = new GlideRecord("sys_user");  // Create a GlideRecord for the User table.
    userRecord.get(this.getParameter('sysparm_userID'));  // Use the sysparm_userID passed from the client side to retrieve a record from the User table.
    return userRecord.department + '';  // Return the department for the requested record
  type: 'GetUserDepartment'
(BTW, does anyone know how I can check the computer-friendly names of the columns in the sys_user table?)
Would anyone be kind enough to give me hints on how I can complete the client script?
Any help would be greatly appreciated!
13 REPLIES 13
You are using getXML(), in this case we need to use getXMLAnswer().
Please check below article to learn more:
https://community.servicenow.com/community?id=community_article&sys_id=1c10a1fedbbd4890feb1a851ca961...
You can update your client script like below:
// THEN pass sys_id of the user
	gaAjax.addParam('sysparm_userID', newValue);
	gaAjax.getXMLAnswer(callback);  // one small change here
	function callback(response) {
		// answer_Dept holds the response of script include
		var answer_Dept = response;
		g_form.setValue('department', answer_Dept);
Or use below logic with response.responseXML.documentElement.getAttribute("answer"):
	gaAjax.getXML(callback);
		var answer_Dept = response.responseXML.documentElement.getAttribute("answer");  / or change this line
Anil Lande
Did you get chance to look at the solution proposed by me?
Anil Lande
Checking right now.
Apologies for the lack of response. I'm the only developer, and I have to go back and forth between multiple user stories. =P
Hitoshi Ozawa
Hi Cédric,
First, is the field Department a reference field to cmn_department table or a Single Line Text? If the original example was using email, it's probably a Single Line Text. However, department in user table is a reference field so returning value of department will only show sys_id of user's department.
Case 1: Department is a reference field to table cmn_department.
Client script
    var ajax = new GlideAjax('GetUserDepartment');
    ajax.addParam('sysparm_name', 'getDepartment');
    ajax.addParam('sysparm_userID', newValue);
    ajax.getXMLAnswer(function(answer) {
        if (answer.length > 0) {
            g_form.setValue('department', answer);
Script include. I've changed "GetEmailAddress.prototype " to "GetUserDepartment.prototype"
var GetUserDepartment= Class.create();
GetUserDepartment.prototype = Object.extendsObject(AbstractAjaxProcessor, {
Execution result
Case 2: Department is a Single Line Text
Client script is the same as above.
Script include
        return userRecord.department.name; // Return the department for the requested record
Execution result
Konichiwa!
I tried your script include, and I got this error message:
But when I replaced "Object.extendsObject(AbstractAjaxProcessor, {" with "Object.extendsObject(global.AbstractAjaxProcessor, {", the script include simply stopped working.
What should I do? (╥︣﹏᷅╥)
