‎11-03-2025 12:59 AM
When user opens any incident which has child incident then there should be message saying for assignee group members that "This incident is parent for INCXXXXXX", child incident needs to be resolved before resolving parent incident, how to implement this scenario?
‎11-03-2025 01:10 AM
Hi @vidishaagarwal5
Method 1 : Display BR with On Load Client Script
We can write display BR to check if current incident has any child incident. Store result in scratchpad object and access scratchpad in on load client script to show message accordingly.
Method 2 :On Load Client Script with GlideAjax
We can write onLoad Client SCript with GlideAjax and check if current incident has any child incidents in server side code.
let me know if you need Script!!
‎11-03-2025 01:14 AM
Hi @vidishaagarwal5 ,
You can follow below to get the solution.
1) Create a Display business rule and use script below.
(function executeRule(current, previous /*, gs, script_include*/) {
g_scratchpad.showChildIncidentMessage = false;
// Check if the current user is a member of the incident's assignment group
if (!current.assignment_group.nil() && gs.getUser().isMemberOf(current.assignment_group)) {
var childIncidentNumbers = [];
var grChild = new GlideRecord('incident');
grChild.addQuery('parent_incident', current.getUniqueValue());
grChild.addQuery('state', 'NOT IN', '6,7,8'); //use state value as per your requirement
grChild.query();
while (grChild.next()) {
childIncidentNumbers.push(grChild.getValue('number'));
if (childIncidentNumbers.length > 0) {
g_scratchpad.showChildIncidentMessage = true;
g_scratchpad.childIncidentList = childIncidentNumbers.join(', ');
})(current, previous);
2) Create onLoad Client script on incident table and use below script.
function onLoad() {
// Check the scratchpad variable set by the display Business Rule
if (g_scratchpad.showChildIncidentMessage === true) {
// Build the dynamic message
var message = 'This incident is a parent for: ' + g_scratchpad.childIncidentList +
'. Child incident(s) need to be resolved before resolving this parent incident.';
// Display the message at the top of the form
g_form.addInfoMessage(message);
Vishal
‎11-03-2025 01:35 AM
Sample Script :
Method 1: Display Business Rule + On Load Client Script
Display Business Rule (server-side)
Table:
incident -
When: display
Script:
(function executeRule(current, g_scratchpad) {
var childGR = new GlideRecord('incident');
childGR.addQuery('parent', current.sys_id);
childGR.addQuery('active', true);
childGR.query();
if (childGR.hasNext()) {
g_scratchpad.hasChild = true;
g_scratchpad.childNumber = childGR.number; // capture one example child INC
g_scratchpad.hasChild = false;
})(current, g_scratchpad);
UI Type: All
Script:
function onLoad() {
if (g_scratchpad.hasChild) {
var msg = "This incident is parent for " + g_scratchpad.childNumber +
". Child incident(s) must be resolved before closing the parent.";
g_form.addInfoMessage(msg);
}How it works:
The Display BR runs before the form loads and sets values in g_scratchpad. The client script reads them on load and shows the message.
grChild.query();
function onLoad() {
Vishal
