Script not running in native UI
09-02-2026 04:41 AM
I have written an onChange client script on server_name variable which is a list collector variable. This script is working in portal, but not in native UI
In native UI even the alert is not coming
09-02-2026 06:35 AM
It is not working, tried to add alert statement as well , the alert is also not coming
09-02-2026 11:24 PM
HI @SHALIKAS , If the script is working on the catalogs then it should also work on the native UI as well.
First make sure you have created a new client script and called the script include appropriately in catalog client script (same script include used for catalogs should be fine).
Can you share the screenshot of the client script form?
If this response helps you mark it as accepted solution and give it a thumbs up 👍. This help me and community to find answers quickly.
Best Regards,
Saurabh V.
