Using a Lookup Select Box to Narrow options for Second Lookup Select Box
05-19-2025 03:23 PM - edited 05-20-2025 05:44 AM
Hello, Developers!
Here's the low down:
- I have two lookup select box variables on my catalog item that I want to filter the same table
- The first one should filter based on a field we're using as a flag called "type" and it should equal to "category"
- The second field should filter the same table with the "type" equal to "topic" AND it should show records from the table that have a "parent" field (reference field for the same table with "name" field as display value) set to the same option selected from the first list select box
Here's what I've tried:
- An advanced Reference Qualifier
- javascript:'parent='+ current.variables.category
- javascript:'parent='+ current.variables.category.toString()
- I tried a script include
- Code:
var CategoryReferenceQualifier = Class.create();
CategoryReferenceQualifier.prototype = {
initialize: function() {},
getSysIdFromName: function(name) {
try{
var categorySysId = '';
var gr = new GlideRecord('my_custom_table_name');
gr.addQuery('category_name', name);
if (gr.next()) {
categorySysId = gr.sys_id.toString();
return categorySysId;
catch (ex) {
gs.error("Error in getSysIdFromName: " + ex);
return '';
getReferenceQualifier: function(type, categoryName) {
var categorySysId = this.getSysIdFromName(categoryName);
if (!categorySysId) {
return '';
gs.info("Here's the sysID: " + categorySysId);
gs.info("Here's the type: " + type);
return 'parent=' + categorySysId + '^type=' + type;
type: 'CategoryReferenceQualifier'
};- Reference Qualifier: javascript: new CategoryReferenceQualifier().getReferenceQualifier(current.Variables.category)
N.B. I used the .toString() method and the script include just in case the the "parent" reference field I'm trying to filter by needed a sysId as a string. I'm not even sure what the first list selector box data/value would look like. Is there even a way to debug reference qualifiers? I've looked at product documentation and nothing seems to be doing the trick. Please help!
05-20-2025 05:52 AM
try this ensure the 1st variable has Lookup value field set to SysId
11-25-2025 09:08 AM
Just come across the same issue - doesn't look like you can have two variables referencing the same table if the second variable is a lookup referencing the first variable.
Very annoying!
I guess the workaround would be to use an on-change client script and GlideAjax but horribly complicated for something so routine.
